B running temp?
van robinson
01-09-2006 23:32:10
I have read many posts from you fine folks saying that the engine temp of A's and B's and such need to get up and stay at about 180 to 190 degrees to prevent plug fouling. I understand this reasoning if using the distillate used back when my tractor was made (1940). But I do not see how this will affect it much today with the advances made in gasoline since then. I only run gasoline in it now. Also, how could I make something similar to the distillate if I took a notion?
buickanddeere
01-11-2006 16:20:02
 Re: B running temp? in reply to van robinson, 01-09-2006 23:32:10
Gasoline, diesel, all-fuel or LP engines. Run them at 195F in order to operate more efficient and last longer.
old
01-10-2006 07:41:52
Back when diesel was cheaper then gas we would mix a 50/50 mix of diesel and gas and my 1935 B would really run/work good on it. It would also puff out big smoke rings at idle. We also found it would pull beter on that mix then it would on just plain gas.
BushogPapa
01-10-2006 06:14:43
Run them at 170+ degrees if for no other reason, for the fact that cylinder wear is Greatly reduced when the engine is run at "Operating Temp"..
Doubt it..??? Look at a high mileage in-line engine and see which side of the front cylinder is worn the most...it will ALWAYS be the Front side..where the COOL coolant impinges on that cylinder..!! Ron..
Mike M
01-10-2006 06:39:33
 Re: B running temp? in reply to BushogPapa, 01-10-2006 06:14:43
But 2 cyls. always wear on the top side of the cyl. walls and the cold comes in at the bottom of the head. It is for sure the best to warm them up and get them out working. I putt around and start and stop mine and don't get to work them,but still I don't see this problem showing up even with as little use as I give some of mine. I even have a couple with the "dreaded" champion spark plugs. I always attributed this to having them in top condition. But I had an unstyled B this summer I picked up and it would start and run fine very surprising since nothing was done to it and it smoked terrible and even sent oil droplets out the stack. I guess all this proves is that they can start and run good even when shot.
Mike M
01-10-2006 05:50:50
I have had some engines even in bad shape that didn't really seem to foul the plugs even without shutters or being warmed up. I don't fully understand why there seems to be so much trouble with it ? I suspect poor ignitions and improperly set carbs. ? Maybe I just have the magic touch ?
I have played around with a couple of my all-fuel tractors fuel. One was able to run on #2 diesel the other wouldn't. Kerosene seems to work good in most of them. If a little gas is mixed in it even works better. I was plowing with my 46'A once and switched from gas to kerosene halfway down the field. I could not tell any difference except for the smell. I'd start out and try straight kerosene and see what happens every tractor runs different. And if you happen to have gas pistons in it you will know because as soon as it pulls a little like a light grade it will start to knock like heck ! If yours does this DO NOT run it on all-fuel any more.
