3010D Main Bearing Question???
CKinSD
01-09-2006 16:20:03
I am overhauling my 3010D as it started dumping coolant into the crankcase this summer. Question is, it appears to have federal mogul main bearings, and each one has the following number:
first line: 3126 CP
second line: FM
third line: PF, SH. or ND on thrust bearing.
at local JD dealer, and they can not cross reference these numbers to see if they are standard or if crank has been ground. rod bearing number they were able to cross refernce to standard size, if that helps...anybody know these FM numbers, or any other ideas, other that micrometer on main journals??? Thanks in advance for any help
Earl -IL
01-10-2006 19:18:53
 Re: 3010D Main Bearing Question??? in reply to CKinSD, 01-09-2006 16:20:03
CKinSD, In the 30,40,&50 bearings had the size stamped on the back usually after the part # example -3126CP.010. Evidently they decided to save money and then stamped on the back with ink.What do you think happened then? Right, you couldn't read it or it just disappeared. Earl
JD man in SD
01-10-2006 18:42:54
CK i live at Madison if not to far four you i have brg mike and can check it you no charge for fellow SD
CKinSD
01-11-2006 05:42:48
 Re: 3010D Main Bearing Question??? in reply to JD man in SD, 01-10-2006 18:42:54
I live 4 miles east and 1/2 north of the Prostrollo buffalo in Madison...small world...I got them measured yesterday and have a rebuild kit on order now...where you at in Madison?
JD man in SD
01-11-2006 15:46:30
 Re: 3010D Main Bearing Question??? in reply to CKinSD, 01-11-2006 05:42:48
i live 1/2 north 2west& 1 north of you My wife got some pop corn from youf little cub scout if you need help on tractor stop over i ran Kents Tractor Serive for 35 years
Bob
01-10-2006 08:18:20
Typically, the Federal Mogul number does NOT change between standard and UNDERSIZE bearings, just a suffix of the actual undersize gets stamped on them, next to the part number.
I have a FM bearing master catalog, and will try to remember to look up that number later today, at the shop, and post back later.
msb
01-09-2006 20:15:54
I never saw a main or rod bearing that wasn't marked oversized by the amount of the oversize i.e. .020, but Earl gives good advice below. You could also use some plasti-gauge on it to be sure.
Earl-IL
01-09-2006 18:14:07
Take the insert brg to a good automotive machine shop. My Federal Mogul brg manual says that 3126 CP STD. brg should be .1264 thick in the middle. It tapers to the parting line (end of brg.)If it measures .1314 ,.005 thicker it is a .010 undersize. It has to be measured with a BALL micrometer with the ball on the inside of the brg. curvature. We always stamp the crankshaft size (.010)on the counterweight.Hope this helps. Earl in Illinois
