Tom in Central Pa.
01-09-2006 16:05:39
Re: 300 B power reverser tranny in reply to bobdod, 01-09-2006 15:29:46
First, it"s best to get a manual. Crawl under the belly of the tractor, You will see a shaft across the underside of the transmission. It connects the clutch pedal to the transmission control valve. There is a pin that goes thru the shaft, if there is any looseness there, fix it first. Use a new pin, oversize pin, double split pin etc. Adjust the clutch free play, then the cross shaft. When the cross shaft adjustment is loose, you can rotate the shaft from a free play position to pressure against a spring-loaded valve. The goal is to have the clutch pedal back against the stop, and at the same time,the spring-loaded valve should be fully loaded against it"s stop. When you push the clutch pedal, the valve dumps the trans oil press.Then as you push the pedal on down, the engine clutch is released. The reverser linkage needs to have the slop removed, by shims, washers, replace the rod, pin, and clevis, etc.
