JD 1830 - diesel in oil crankcase
Dan.C
01-09-2006 09:12:05
I checked my oil and noticed it didn't look quite right.
So I drained it and it didn't look or smell (diesel) bad at that time. I let the tractor sit after draining it for about 4 weeks. I then went back to see if any water might be present and found about 1/4 to 1/2 gallon of diesel in the bottom of the oil pan. My question is could a "bad" injector leak this much with the tractor not running ? or am I looking at the lift pump leaking fuel in the crankcase ? Please help and thanks in advance.
Matt in PA
01-10-2006 08:25:11
 Re: JD 1830 - diesel in oil crankcase in reply to Dan.C, 01-09-2006 09:12:05
Dan,
I had a similiar problem with my 401C. I had the injector pump rebuilt and when I installed it the rubber cup that seals the shaft from the engine oil and diesel got twisted and dumped fuel into the oil. I was told that these seals can go bad over time and begin leaking large amounts of fuel. I do not know if they will leak when the tractor is not running. You might want to try and isolate the problem by pull the fuel line after the transfer pump.
Matt
Tx Jim
01-10-2006 03:21:29
Dan,either lift pump or injection pump is leaking probably not injector. Tx Jim
