I posted a problem I am having with my 73 2030 a while ago, I have new information and was hoping to get some additional input. I have copied in part of my previous post below:I have a 73 2030 with a hydraulic system problem. No reverser, no Hi/Lo shift, single rear live PTO. After running for a few min. the system starts to chatter, line vibrate, using loader, 3pt, or just sitting there doing nothing. I have changed filter, screen, and fluid. I have looked at filter by pass valve, surge relief valve, several pistons in front pump and the check valve in the supply line from rear pump to front pump. I think front pump is starving for fluid causing chatter. I�ll add now that if I turn the tractor off while it is having this hydraulic line vibration problem, the reservoir up front is pretty much full. I have also since put a pressure gauge in the remote which reads only about 1200-1500 psi when no vibration and fluctuates from 0 to 1500 when vibrating. I guess the fluctuation is caused by the pressure control valve opening and closing. I then put the gauge in the top plug of the front pump. Pressure was about the same, although when it vibrates with gauge in front, fluctuations are 1000 to 1500. Turning the stroke control valve adjusting screw makes no change in pressure. I took the stroke control valve out the bottom and spring isn�t broken. I have also had the front pump out and inspected each inlet and outlet valve. They are not new, but don�t look to be terribly worn. I am getting ready to buy a new front pump. Before I did that, I wanted to try one last time here to see if anybody smarter then I am had some advice, or knows of something I haven�t yet considered. Any insights are welcome. Thanks.
