2510 clutch slipping?
paul d
01-09-2006 06:17:00
got a 2510 diesel and the clutch slips under a load. took it apart and the clutchs have oil on them. looks to be coming from the seal on the drive shaft going back to the trans where it is a double shaft. wondering if anyone has experiencein this department. i don't want to tear tractor apart again if i can help it. thanks paul
msb
01-09-2006 08:00:21
 Re: 2510 clutch slipping? in reply to paul d, 01-09-2006 06:17:00
There are two seals that could be the problem.The first one is on the end of the PTO input shaft and seals the space between the transmission input shaft and the PTO input shaft.Its a rather small seal.This seal will usually make only the engine clutch plate wet.If its really bad or left to leak then the PTO plate also is involved.
The second seal is behind the clutch housing where it can't be seen and seals the PTO input shaft from leaking.If the PTO input shaft is wet towards the rear of the shaft then it is probably that seal that is leaking.To get to that seal the center section between the engine and transmission must be removed or swung as the terminology goes in most shops.Its not a really hard job but requires the use of a cherry picker,a frame hoist or floor crane to swing the center section on.
paul d
01-09-2006 08:18:21
 Re: 2510 clutch slipping? in reply to msb, 01-09-2006 08:00:21
the pto clutch plate was wet also. so i guess i will pull that next housing to get to that other seal you were talking about.
