FH SPOKE WHEEL
STEVE BARCO
01-08-2006 14:22:10
ANY IDEAS HOW TO SEPARATE THE WHEEL FROM THE HUB?THE BOLTS IN THE HUB ARE NOT ENOUGH TO PUSH THE WHEEL OFF.PENETRATING OIL AND POUNDING-NO LUCK,SO FAR? THANKS,SB
greenmech
01-09-2006 19:38:11
 Re: FH SPOKE WHEEL in reply to STEVE BARCO, 01-08-2006 14:22:10
SB ,are you talking about the hub clamp .does not loosen? Maybe a lot of heat on the clamp and then tighten the bolts. Ron Mn.
sbarco
01-14-2006 07:21:04
 Re: FH SPOKE WHEEL in reply to greenmech, 01-09-2006 19:38:11
I'm not sure? I think the ring that the six bolts pass through, that tie to the cast wheel hub is part of a sleeve that is on the axel.My guess is, you have to move the spoke wheel towards the tractor , to get to the hub thats clamped to the axel. I'm just trying to get the wheel moved off this axel clamp.thanks for the help
