Clutch release question
JD1520Guy
11-16-1999 09:28:28
I had posted a question a week or two ago about a problem I was having where the gears in the transmission seem to take a long time to stop (5-10 sec) after the clutch was pushed in. This causes some grinding when going from neutral to a gear if I didn't wait. I now have the tractor (JD1520) split at the transmission and I am replacing the snubber pads. With it apart I would like to see if the clutch is completely releasing. My question is if I hold the clutch petal in how hard should it be to turn the main drive gear? Should it be free enough to turn by hand? Spin freely?
david val
11-17-1999 12:22:37
 Re: Clutch release question in reply to JD1520Guy, 11-16-1999 09:28:28
the clutch shaft with the disk should turn pretty eazy. the shaft is supported in a bearing in its front end. if you turn it fast enough it should continue rotating on its momentum.
Mike H
11-16-1999 18:10:14
Seems like it should turn by hand but not freewheel
