Chainsaw sparkplug getting a stalagmite help?
Nylon
01-07-2006 23:21:43
I know this is way off subject but....
I have a huskvarna model 51 chainsaw. I jinxed myself by thinking (and I swear to this) just a day before this started happening how great this saw has been after 10 years of pretty good use. Any way this started out of the blue. SAme mix same oil same as usual. It can be made to run at higher rpms but not real smooth. Once it is at idle, it runs a bit erratic and rough and dies. Then it is hard to start but can be done. I had never changed the plug in it. Only cleaned it every so often so I pulled it out and noticed a chunk of stuff between electrode and wire like a stalagmite. I cleaned it out and ran fine for a bit and same thing. So repeat cycle 3 - 4 times. Everytime same thing. So I go get a new plug. Same thing. Spark looks nice and strong on both plugs but I keep gettting this little chunk of stuff bridging the spark plug gap. The plug is really pretty clean after the first removal other than the chunk accross the gap. So it isnt all fouled up, just normal clean looking burn. Any ideas on this. I tried getting a look at the piston head and it looks as though there is some carbon on top of it. I cant really tell but wondering if it is flaking off and that is what is bridging the gap? The air filter is always in place and very clean and carb is spotless. Any thoughts would be greatly appreciated. Also if it is the carbon...is there anything to dissolve that rather than have to take the head cap off?
Thx,
John
wmw
01-08-2006 15:24:09
 Re: Chainsaw sparkplug getting a stalagmite help? in reply to Nylon, 01-07-2006 23:21:43
Look close at the deposit. It may be the saw is running lean and overheating the piston. The melted aluminun will build up on a plug like you're describing.
Wheaty
01-08-2006 15:13:19
It sounds like it might be an oil type issue. Are you using Husquvarna oil? Have you always been using the same type of oil, and now are just having the issue? I believe that Husquvarna manufactures a synthetic oil. They burn ALOT cleaner than petrolium based oils. Has the saw been used alot through out its lifetime? Have you ever had the saw reringed, and are the reeds in good shape?
donmyeil
01-08-2006 08:30:26
DONT KNOW A LOT ABT CHAIN SAWS EXCEPT THEY ARE WORK. ARE YOU USEING A GOOD LOW ASH OIL. SOUNDS LIKE MIXTURE IS OFF AND FOWLING UP THE CYL. JUST A THOUGHT. DON
Hoosier JD
01-08-2006 09:31:40
 Re: Chainsaw sparkplug getting a stalagmite help? in reply to donmyeil, 01-08-2006 08:30:26
This might sound silly....what exactly does "low ash" mean and what are a couple of examples. Thanks, Mike.
Chrisfromsolitude
01-08-2006 13:24:08
 Re: Chainsaw sparkplug getting a stalagmite help? in reply to Hoosier JD, 01-08-2006 09:31:40
When you burn oil you have a certain amount of ash left. Different oils leave different amounts of ash after they have been burned. You can try this by taking a ceramic bowl (dry and clean) and set it over a flame with oil in it. When the oil is gone you will see the ash. You can try it with a good oil and then try the cheap stuff from a gas station and you will see a big difference. I can't remember any examples but when I was in school we had an instructor that could tell you all about this stuff. I really learned alot about oils but can't remember half of it. I think maybe a diesel oil may have less ash than one designed for a gas motor. Then you have some additives that help eliminate ash too. I hope this might have helped but you may be more confused now than when I started.
