Hard to turn 1938 A
BobB
01-07-2006 18:09:44
I have an A that is hard to turn over sometimes. I recently took the block and pistons out for paint and overhaul. Now sometimes when I try to spin it it is very difficult to move particularly when they are at the ends of the stroke. Other times it seems to spin fairly easily. I have not got it running yet either.
P.S. what is a normal torque for the bolts on the connecting rods.
mbptractor
01-07-2006 19:44:17
 Re: Hard to turn 1938 A in reply to BobB, 01-07-2006 18:09:44
100 ft-lbs for series A With 0.003 running clearace for oil. I had one of my unstyled A'S that sat for years and was tight like that and it was the clutch was binding up i took it a part and cleaned it and put new lineings in it and it fixed that problem.
40 JD G
01-07-2006 19:34:45
When the crank gets wore after many years they get out of round and have a flat spot on them, and if you take to many shims out the the rods it can get tight when the crank is horizontal. If you take more shims out then it will probly knock. The only good way to fix it is to have your crank ground and re-babit the rods accordingly, then it gets expensive. Hope this helps
Nick
