720 jumping out of gear
Russ
10-27-2003 06:13:33
720 jumps out of gear when under load.This happens in all gears.It looks all right inside the gear box.
MIKE HANLEY
10-27-2003 17:39:27
 Re: 720 jumping out of gear in reply to Russ, 10-27-2003 06:13:33
Try the easy stuff first. Grap the shifting lever and pull it up and down. There should be no up and down movement. If there is put in a new spring at the end of the shifting lever. What happens is when this spring gets weak, you shift and you think you are fully in gear as the lever is all the way over in the slot. But with a weak spring the ball at the end of the lever is not fully in the shifters and not sliding the gear over far enought to lock into the detents. Next try the ajustments, but usually if it's out of ajustment it will not be poping out of all the gears. Bring down the shifting lever to the cross over slot and just after you enter the crossover slot feel for dead nutrual. Mark that point with a pencel. The do the same thing on the other side and also feel for the dead nutural point on that side. The two pencel marks should be the same distance from the outside of the shifter casting to the pencel marks.
