820 crank specs needed
SKIP 33652
01-06-2006 17:20:54
I would really appreciate anyone that could send rod and main specs my way crank needs ground and need specs to grind Thanks Paul
Duane Larson
01-06-2006 18:33:09
 Re: 820 crank specs needed in reply to SKIP 33652, 01-06-2006 17:20:54
Skip,
Here you go..
Crank journal at pulley bushing - 2.9961-2.9975"
Crank journal at connecting rod bearing - 3.9991-4.0005"
Center main journal - 4.4975-4.4985"
connecting rod bearing - 4.0020-4.0040"
Main bearing RH - 4.5045-4.5055"
Main bearing journal RH - 4.4975-4.4985"
Main bearing LH - 4.5045-4.5055"
Main bearing journal LH - 4.4975-4.4985"
Center main bearing - 4.5006-4.5030"
Info from JD Field Service Bulletin 259 11/57.
Skip 33652
01-06-2006 17:42:59
 for a two cylinder sorry in reply to SKIP 33652, 01-06-2006 17:20:54
no text
