4020 Hydraulic Pump(s)
MRN
01-06-2006 15:31:46
Our 1968 4020D Syncro's hydraulic pump suddenly started making a bad knocking noise and stopped pumping (no steering, 3pt hitch ops, etc.). The hydraulic fluid dipstick read full. The pump has always made some noise, which I understand is normal, and operated fine.
Being the eager lad that I am I figured the pump needed replacement and proceeded to remove it. Now that the pump is off (and after reading posts on this forum) I'm having second thoughts. I have subsequently removed the transmission filter and cranked the engine which according to the I&T manual should provide "a generous flow" from the filter housing, well it didn't (the trickle that drains when the filter is out just about doubled). Furthermore there was very little hydro fluid in the cooler when the pump came off. So, does it sound like the main pump was possibly starved by transmission supply pump? I understand that the screen can become clogged and restrict flow. (where exactly is the screen access point?) If I find the screen is clogged and clean it, should cranking the engine with the main pump off provide good flow out of the supply line (main hydro pump, front of tractor)?
Thanks for your reply and patience.
msb
01-06-2006 19:36:41
 Re: 4020 Hydraulic Pump(s) in reply to MRN, 01-06-2006 15:31:46
Knocking noise? AH HA! First of all, did you look to see if the splines in the drive coupling were intact.Those pumps have been known to shear the splines off and end all hydraulic function.Can the pump be turned with a large pair of pliers?
The suction screen is located towards the rear of and behind the transmission filter and usually takes a 1"(I believe) square or could be a hex plug wrench to remove it,but drain the transmission first or all the oil will come gushing forth when the screen plug is removed. Cut the filter apart and see if it is loaded with bits of brake lining.The nitrogen filled accumulator mentioned in the other post is on the 69 through 72 models and only is to serve the steering and braking in case of engine failure.Your 68 model won't have one.
The tramsmission pump is not all that big and won't pump a lot of oil at cranking speed so don't expect to see a gusher.Good luck and I hope your removal of the pump was a waste of energy on your part and its just the drive coupling.Replace that fan belt will you have the coupling apart and install new nylon bushings on the coupler too.
MRN
01-07-2006 07:26:42
 Re: 4020 Hydraulic Pump(s) in reply to msb, 01-06-2006 19:36:41
The drive coupler was good and tight, no slop at all, no broken splines.
The pump can be easily turned by hand and sounds like one of those old Jack-In-Box toys when turned, kind of a metallic poping sound. (all of the fittings are off).
I'll remove and clean the transmission pump suction screen today, replace the fluid and filter with new and see if it looks like anymore volume is pumped by the transmission pump. How can you tell if the transmission pump is not working correctly? After that I guess the next step is to try and find a shop to test/inspect the main pump and see what those results are. Are there any inspections I can easily do for obvious problems?
Thanks for your suggestions and help.
msb
01-07-2006 21:18:59
 Re: 4020 Hydraulic Pump(s) in reply to MRN, 01-07-2006 07:26:42
HMMMM? Jack in box noise not good.Sounds like a bearing failure.The pistons in that pump are forced in on the crank roller by oil pressure of the transmission pump,so since they are pushed away fron the crank they should no longer contact the crank roller.Turning the pump by hand should make very little if any noise.
zwr
01-06-2006 18:02:40
I'm sure you know, but just in case: The supply pump is driven thru the tranny. The tractor's drive clutch must be engaged, especially if the nitrogen-filled "pressure reservoir" leaks down--not uncommon in older tractors.
