1942 JD A.
frank van den d
01-05-2006 20:03:04
a bit confused as to proper carb float level. got a new kit but it came with tsx instructions.
frank van den dorpel
01-06-2006 18:00:15
 Re: 1942 JD A. in reply to frank van den dorpel, 01-05-2006 20:03:04
thanx to every one for your help.
Glen in TX
01-05-2006 21:29:41
On the DLTX on your A you want to make a preliminary setting of the float by holding the float bowl upside down with needle valve seated and measuring 3/8" from bowl edge to top of float. Then after on the tractor can check it again with a barb hose fitting screwed into float drain and a piece of hose and a clear glass tube or clear tubing on end of hose and then when fuel is turned on and holding the tube to top edge of the float bowl your fuel level should be 3/4" below top bowl edge.
Mike M
01-06-2006 03:29:42
 Re: 1942 JD A. in reply to Glen in TX, 01-05-2006 21:29:41
The real late A's and B's were to be set at that 3/8" figure (which can cause black puffs when on ruff ground)Up to about 1948 they were all to be 1/2" which is where I set them all at as it has served me better.
Glen in TX
01-06-2006 07:02:58
 Re: 1942 JD A. in reply to Mike M, 01-06-2006 03:29:42
Yes, it was recommended to set the DLTX 67,71,72 & 73 floats at 1/2". Always good to set them all just a bit on low side if they aren't going to be working anyway.
