Bering adjustment
Green B
01-05-2006 19:25:58
I need to know what the plasti gage should read on a unstyled B main and crank berings. Thanks
Mike M
01-06-2006 03:36:56
 Re: Bering adjustment in reply to Green B, 01-05-2006 19:25:58
No need to use plasti gauge on them even if you can get it to work as on the rods it is very hard to tighten them without haveing to rotate the crank. The shims were .003 each, you remove 1 each for the top and bottom keeping everything equal.Then tighten it up if it binds up add 1 each back in and tighten it back up if it then spins freely your good to go. If it doesn't bind up first try remove 1 each more and repeat. I like to remove all the shims and measure the stack with a mic to make sure they are equal before starting to adjust them.
