40B timing
van robinson
01-04-2006 22:56:52
My B will not run smooth idling or revved up a bit without a load on it. I have cleaned carb good, and tried all adjustments on the carb. If I put a load on it,the tractor runs great. If the timing is off, could that cause this? Seems to me that it should run just as rough with a load as it does with no load if the timing was off. Ideas?
Thanks.
sgt bull
01-05-2006 08:07:20
 Re: 40B timing in reply to van robinson, 01-04-2006 22:56:52
Have you had the center nozzle out of the carb? It has a reserve well in it to take up the slack when you accelerate or the governor opens up...they are difficult to take out sometimes w/o damaging. I always had good luck bead blasting the area in the casting below the tube first (or otherwise cleaning it up really well), then running a small tap into the hole in the bottom of the nozzle that corresponds with an appropriate long bolt.....(i have an old generator bolt, the long ones that hold the endplates together, and it took a 12-24 tap). Then take a crescent wrench, like a 12" or so, dial it down to where you can just use slide it on the bolt, and use it like a slam puller, sliding it down hard on the head of the bolt, pulling the nozzle. A little heat to thecasting can help, but it makes the carb hard to hold.Having soaked it in a carb cleaner helps too, but it is mostly rust from the casting holding the nozzle in...do this over something soft when you do...it needs to be in your hands, not a vise...seems like it'll pull it right out of a vise, but your hands can kinda work like a shock absorber while still holding it enough to work In any case, you don't want to haveit hit the floor. It may take several raps, but it most likely will come free. Whatever you do, don't pry down on the nozzle from inside the venturi...your just asking to ruin it.
old
01-05-2006 07:41:49
My B never has run smooth as say a ford or oliver. That shouldn't either. My B runs the same as it did when my grandfather used it to farm with back years ago. They are a hit and miss type engine and will only run smooth with a load if they are running they way they should. With out a load they should go pop pop then miss a couple times and then go pop pop etc. Thats why they are called popping Johnnys.
van robinson
01-05-2006 00:31:53
I did clean all of the passageways with drills according to roberts carb website. The throttle shaft or bushing is worn a bit, but I do not believe is is worn bad enough to cause this problem. The throttle plate is ok. I tried the idle and load jet adjustments, but no change. When the throttle lever is pulled back to an idle, should the throttle plate close almost completely? If not, how much of an opening should it have?
Pappy
01-04-2006 23:20:04
Check for air leaks around the carburetor to manifold gasket. Check the throttle shaft for excessive wear. Check the throttle plate to be sure it fits the bore properly. Also, check the idle speed adjustment screw to see if it fits against the spring to keep the throttle steady. Try opening the idle adjustment 1.5 turns open and the load adjustment 1.0 turns open. Then make your fine adjustments. Be sure the carburetor is clean. Passages must be cleaned with drills to get the rust out. Soaking usually won't do it.
