3020 dies when warm
kurt keeler
01-04-2006 12:58:33
I"ve got a "68 gas 3020 with synchro. I recently put in a manual destroker. Tractor starts up great and was running great until the last week or so.
When the tractor gets warmed up, it dies. It will crank and ALMOST get running but doesn"t quite make it. It kinda acts like a fuel filter getting plugged, but I"ll be damned if I can find a fuel filter (is it hidden somewhere?).
It"s got fresh gas (with SeaFoam) in it. It was serviced before I got it a couple of months ago (points, plugs, etc.)
Anybody got any ideas?
kurt keeler
01-09-2006 11:28:39
 Re: 3020 dies when warm in reply to kurt keeler, 01-04-2006 12:58:33
Thanks for all the tips,,, I"ll look into them as time allows.
This board seems to be full of helpful people with a vast amount of experience. It is very helpful to us "newbies".
Mike M
01-05-2006 17:11:35
Had something similar on our 4020. Spark looked good ? Tested fuel flow while cranking transfer pump seemed weak ? Our pump looked old and they don't cost that much so I put a new on one and it cured it.
Larry in WNY
01-05-2006 09:15:02
If your 3020 gas has a fuel filter, it will be in-line between the fuel pump and carburator. I replaced the fuel line between the pump and carb. on my 3020 and the new line has a filter on it. This was a update over the original line.
Larry
msb
01-04-2006 17:22:12
Remove the fuel line from the tank at the fuel pump asnd see if the line is clear.Could be the line from the tank is partially plugged and lets just enough gas through to fill the carburetor and then doesn't flow enough gas to keep the tractor running.
G/MAN
01-04-2006 13:18:20
See if you're still getting a good spark right after it dies. A lot of times a bad coil will act like that - work fine when cool but go to pot when it gets hot.
kdagenais
01-05-2006 16:28:37
 Re: 3020 dies when warm in reply to G/MAN, 01-04-2006 13:18:20
Another thing to check is make sure the fuel valve at the bottom of the tank is all the way open. Could be half open and not able to maintain proper flow under a full load on the engine.
