1-1/2 hp Type E Mag
Tom/Idaho
01-04-2006 05:08:19
How much voltage should I expect to see when turning the gear by hand?
My instructions booklet for this motor says,"slot in end of needle valve seat must be horizontal". Where is this slot? Thanks for any help.
Tom/Idaho
Tom/Idaho
01-05-2006 05:28:20
 Re: 1-1/2 hp Type E Mag in reply to Tom/Idaho, 01-04-2006 05:08:19
Mr. Larson, thank you for your assistance. The little motor now runs like it used to. Tom/Idaho
Duane Larson
01-04-2006 06:48:50
Tom,
If you look at the brass piece (seat) where the needle screws in, there will be a line scribed across its face - some are more obvious than others. The brass seat needs to be turned while threading in so the line is horizontal.
The magneto is a small ac generator, so flipping by hand should give a needle kick on an analog meter - a digital meter should show something but hard to say what. The voltage pattern generated by the magneto is not a true sine wave typically associated with ac, so it is not accurately measured by a voltmeter, and looking at the voltage on a scope is the best way to determine the maximum voltage. Since the voltage is roughly proportional to the rpm the shaft is driven at, I normally read 20-25 volts ac at 500 rpm on a digital voltmeter after charging the magnet. If you try this, be sure to couple your driving source (like an electric drill) to the magneto shaft with a piece of rubber to account for the fact that it is very hard to get the two shafts on the same centerline, and the forces resulting from different centerlines can be very hard on the magneto.
