420 steering sector
BG in AL
01-03-2006 18:25:53
I need to repair the steering sector on my 420 wide front. The worm gear would twist out of the housing . The problem looks like the bearings are shot, most of the ball bearing are gone and the holders are no longer available from Deere. can a moderm bearing replace the old style or does anyone havea better fix for this problem?
Glen in TX
01-04-2006 10:23:44
 Re: 420 steering sector in reply to BG in AL, 01-03-2006 18:25:53
Some of those steering box bearings are hard to find but I'm not sure about the ones for a 420. Did you try JD for bearings or Greg at theoldtractorcompany.com ? Also might try a industrial bearing supply place and if no luck and the bearing holders are good you might just get new balls at bearing place too.
JD man in SD
01-07-2006 18:31:14
 Re: 420 steering sector in reply to Glen in TX, 01-04-2006 10:23:44
new balls are available from JD
