14T horsepower requirement
BillyinStoughton
01-03-2006 13:09:20
Good afternoon boys! Anybody have any idea what kind of HP I should have to run a JD 14T baler (no kicker). It"s in great shape and has had an easy life. I want to make sure I"ve got the set up to do the job when the time comes around. Thank you!
CMB
01-03-2006 15:39:26
 Re: 14T horsepower requirement in reply to BillyinStoughton, 01-03-2006 13:09:20
We bought a new one in '61. Pulled it anywhere(up hill & down) with a "60", while pulling a 16' rack behind. Worked fine, but in hilly ground I'd hesitate to use a smaller/lighter tractor.
old
01-03-2006 13:39:59
About a 30 HP or bigger tractor works one like it should be worked. Small will pull it but will work a tractor to death. A late model B say a 1950 will do it but thats about all it will want. I usto pull one behind my 841 ford and my Oliver 77 both pulled it well and that was with a kicker on the baler. The Oliver did the better job because of the live PTO. Live PTO also makes pulling a baler better
John in Md.
01-03-2006 13:29:13
In the early 70's we ran one with a Farmall C. But only pulled a flat wagon on flat fields, the rest we dropped on the ground and came back with a flat wagon.
Stan - Florida
01-03-2006 13:18:39
We ran one with both a '49 A and a '52 B. Not sure what the horsepower was, but we pulled a wagon behind the baler on fairly level ground.
Stan
