4020 sleeve o-rings
Elk-A-Holic
01-03-2006 09:17:13
I amrebuilding a 4020 that had a crankcase full of coolant and left sitting for several years. Block was sent in tanked and clesned up. The rebuilder said they needed to rebuild the grooves where the o-rings sealing the cylinder sleeves fit.-$2500.00plus. Took block to local Ag repair business which has a good reputation and they said the grooves were no worse than many they have seen and they wood have no problem rebuilding it. Suggested that I could smooth out the pitting with J-B weld smoothed with a piston ring cutter and then reasemble. Decided to go that route. The Herschel-Adams kit that I purchased has a red and a black o-ring with the red seal being inserted in the top groove and the black in the bottom. The JD manual says the opposite (red in bottom groove). Shuold I assume they use differnt materials for the o-rings and therefore I should follow the directions supplied by the particular manufacturer? Ithas also been suggested that I could insert an o-ring into the middle groove (obliterating the drian hole) as a backup to help stop any leakage. Is this a good idea and what seal should be used? The block is Numbered R33180R. I am not a mechanic and got into this project as a learning experience after sticking my hand up once too often at an aution sale so any info will be much appreciated.
JD JimBo
01-03-2006 20:23:55
 Re: 4020 sleeve o-rings in reply to Elk-A-Holic, 01-03-2006 09:17:13
I'm not sure which o-ring to put in the middle groove, but you should tap the weep hole and plug it with the 3 o-ring setup. Check what o-rings are used on a newer(side console) 4020. They had 3 o-rings and no weep holes.
JD man in SD
01-04-2006 17:07:31
 Re: 4020 sleeve o-rings in reply to JD JimBo, 01-03-2006 20:23:55
it makes no diff.what color ring in middle grove the idea is to fill the middle grove and keep the crap out no need to plug hole. o ring does this 69 and newer biocks use 2o rings & 1 square packing
JD man in SD
01-03-2006 18:00:56
i would get 3 extra oring kits from deere put 3 blacks in front 3cyls middle grove reds in rear i use crisco for lub on sleeves & o rings in forty years off working on JDs i have found the o rings seem to rot from the inside on the blocks with the weep holes
G/MAN
01-03-2006 15:24:17
You might want to double-check the Deere instructions again, but I would also put more stock in the instructions that came with the sleeves and o-rings. Normally though, Deere recommends putting the black ring in the bottom groove also. If you're using an original 4020 manual, it's quite likely that the info is out of date. New Deere liner kits come with instructions in them, and as I said, they always seem to recommend the black o-ring going in the bottom groove.
JGC
01-03-2006 13:21:49
I would e-mail Herschel-Adams to confirm the correct O-ring positioning, or their web-site may include their assy instructions.
Can't help on the 4020 specific questions.
Keep that hand down next time! - LOL
Best of Luck,
Jon
