Correct 4010 tach
msf
01-03-2006 08:04:08
We purchased a late 1963 4010 with an all white tach. If I remember right, 4010 tachs had a green and red stripe on the arch. So, am I right to believe the tractor has a replacement tach?
msf
01-04-2006 13:21:13
 Thanks and in reply to msf, 01-03-2006 08:04:08
apppreciate the replies. The tractor came from an estate and no one knows if the hours showing are right. The hours seem low, but as tight as the transmission is, they could be right. On another note, it is amazing how much better even a diesel will run on new fuel and after a couple fuel filter changes.
Mike Aylward
01-03-2006 17:06:16
 Re: Correct 4010 tach in reply to msf, 01-03-2006 08:04:08
I have a '64 4020 and the tach in it is original and is all white. The green and red stripes came into being around the '65 time frame or shortly thereafter, from the original tractors I have seen over the years. Also, the replacement tach will have two digit numbers on them while the later replacement tachs have four digit numbers (with a second language as well). Hope this helps. Mike
Glen in TX
01-03-2006 10:15:27
Like CMB said I believe the originals were white. Seems like I remember a 5010 we had having the white tach but it was later replaced. I may have a old one in a box too and can look to see if it had those stripes. Later 4020s had the black tachs with white numbers and strip lighting.
CMB
01-03-2006 08:39:56
I THINK the all white tachs are the original style. I have a '61 4010D,on which I had to replace the tach at about 10000 hrs. It's been several yrs ago, but I'm quite sure the original was all white. I remember being dissapointed to find that new one looks NOTHING like the factory one.(I think the old one is on the bench at my other farm, but I'd have to drive 5mi. to check it out.) Seems to me that the green & red striped ones are for the later 4020's etc.
