JD A Clutch Driver and Crankshaft 648,000 and u
Brian Girard
01-03-2006 06:07:51
I have a JD A that someone at sometime let clutch driver bolt get loose and didn't tighten. Now, the splines on both crank and driver are shot. Was wondering if there is a fix or if I can't find correct s/n parts, will earlier A or 60 parts work? And, do you have to used matched set of clutch driver and crankshaft? Thanks, Brian
Mike M
01-03-2006 08:18:18
 Re: JD A Clutch Driver and Crankshaft 648,000 a in reply to Brian Girard, 01-03-2006 06:07:51
They are not matched and the aftermarket sells new ones.A and 60 will be the same. I have tried some of the ones advertised to be undersized but I cannot prove them to be as they measure the same everyway I tried to measure them.Put a new one on and use JB weld to take up the gaps,assemble it all up and snap the clutch in before it sets up then let sit a day to cure.I have also made a 1 pc. shim and put the old one back on with JB weld and it held. Otherwise you will need to get the splines built back up and remachined. In the end you want the crankshaft to be about 1/8-1/4 ideally from comeing flush with the end of the driver or else your clutch will bind up.
