I have only rebuilt one "B" carb and one "D" carb so I am by no means an expert. That said, here are a few thoughts. Modern gasolines start loosing their volatile components within a couple of weeks. Now I always start off with fresh, premium fuel, and add stabilizer to it before I try to solve fuel system problems. 1. Rebuild the carb and THOROUGHLY clean all of the passages, including removing the brass plugs and clean out the long passages with 6" long drill bits if you haven't already. 2. Check the float level with the carb mounted on the tractor. Remove the drain tap on the bottom of the float bowl and thread in a 45 degree or 90 degree 1/8" pipe elbow and thread a 1/8" hose barb into the elbow. Attach a one foot length of clear tubing to the barb, turn the gas back on, and you can observe the fuel level by holding the clear tube against the bowl. If it isn't correct, fix it first. 3. When the load needle is closed and the tractor idles, is the idle needle out 1 to 1.5 turns? If it is way off this range, there is probably an idle circuit problem as well. 4. Check the condition of both needles. The tapers are different and the needles are different lengths. If the area on the needle that contacts the seat is badly worn, or damaged from over-tightening, that could cause some of the problem. 5. The occational miss at idle could be other problems. Worn throttle shaft bushings, a worn throttle shaft, vacuum leaks at the carb flange, bad plugs, weak spark, bad wires, timing off, play in the governor linkage, etc. 6. Robert's Carbs sells the long drill bits and they have some good information on their website about cleaning these carbs. Good Luck!
