1960, 440I, wheeled gas tractor, SR# 453914
Whiteoaks
01-02-2006 09:56:41
I am looking for information about the correct OEM manufacturer and part number for a carburator on this old tractor. If you know replacement manufacturer and carb model number, that would be very helpful too. The engine is supposed to be the later version that was upped to 30hp. Would appreciate any information from the Johnny Popper masters.
Lavoy
01-06-2006 16:31:37
 Re: 1960, 440I, wheeled gas tractor, SR# 453914 in reply to Whiteoaks, 01-02-2006 09:56:41
It is not really that difficult. If you want a new replacement carb, let me know and I will get you one. I just put one on my 440, and for the replacement carb, serial number is irrelevant.
Just a note, the higher serial number machines were rated at 33HP, and used a different head, carb, and had the governor turned up by 150 RPM.
If you want a used carb, I will have to check and see what I have.
Lavoy
Whiteoaks
01-06-2006 19:00:32
 Re: 1960, 440I, wheeled gas tractor, SR# 453914 in reply to Lavoy, 01-06-2006 16:31:37
Sorry, don't mean to make this difficult. I am just one of those hard headed types that was taught to do my homework and do the job right the first time. I just don't want to screw up and get the wrong carb for this old tractor in light of all the other problems I've had with it since I bought it. Got it at an auction to do farm work around my small farm and it's working condition what not accurately described at the time I purchased it. All I need is to go off half cocked, buy the wrong carb, and have more problems to deal with. YOU KNOW>
Glen in TX
01-02-2006 10:24:39
440 (all fuel), Marvel Schebler TSX-768, JD# AT-10576-T, Zenith replacement 014996.
440 gasoline, MS TSX-756, JD# AT-10181-T, Zenith replacement 014996.
440 gasoline (1960), MS TSX-777, JD# ATY-20956-B, Zenith replacement 014997.
450, 461, 501 & 561 used different versions of MS carb but sub to same 014996 Zenith replacement.
MS kits and floats and some other parts are available for them and new Zenith as well.
Whiteoaks
01-03-2006 15:10:07
 Re: 1960, 440I, wheeled gas tractor, SR# 453914 in reply to Glen in TX, 01-02-2006 10:24:39
Thanks Glen for your response to my question. I also received a response from someone through a different inquiry source. Now, to say the least, I'm not a whole lot better off than I was when I didn't know anything. The other person who sent me information says that the original carb was a Marvel Schebler TSX-688 and the Zenith replacement would be a 17A40. Any words of wisdom that would help me determine who or what is correct? Thanks for your help.
Glen in TX
01-04-2006 12:30:49
 Re: 1960, 440I, wheeled gas tractor, SR# 453914 in reply to Whiteoaks, 01-03-2006 15:10:07
I thought maybe you had your year right but serial number lists I have show the 440 in 1960 starting ser. number was 458637. If that is correct yours is a 1959 model using the TSX-756, JD # AT10181T, Zenith # 014996. If it has a small gas tank and a larger fuel tank it was a all fuel using the TSX-768, still replaced by 014996.
Whiteoaks
01-06-2006 18:16:55
 Re: 1960, 440I, wheeled gas tractor, SR# 453914 in reply to Glen in TX, 01-04-2006 12:30:49
Hello Glen,
Well, thats another new one. The serial number/year model information that made me believe mine was a 1960 model came from the "JohnnyPopper.com" web site. They have a page on 440 and 435 JD's. On that web page it says the 1960 model started with serial number 453873 and later. Since mine is 453914 I did the math and came to the conclusion that mine fit into the 1960 category, go figure. I do not understand the difference in what the web site says and what your book says. Do you know of another serial number source that I can get a number from? If you get a chance would you like at the JohnnyPopper web site and tell me if I am wrong in what I saw? Thanks. Thought this would be easy!!!!! !!!!! !!
Glen in TX
01-06-2006 22:02:28
 Re: 1960, 440I, wheeled gas tractor, SR# 453914 in reply to Whiteoaks, 01-06-2006 18:16:55
Ok, Maybe the numbers Brandon has there are more correct and from Two Cylinder research or something? I forgot about serial numbers there too. I'll look at those later. My info on serial numbers could be wrong and came from a blue book and not official JD source. I don't know if there is that much difference in any of those carburetors anyway? Linkage? Jet changes? If the later one fits it would probably be the best one to use because would figure it was updated to run better on gasoline.
Glen in TX
01-03-2006 20:43:50
Whiteoaks, The info I posted above came from a Zenith / Marvel Schebler carburetor catalog. It only listed that info for a 440 crawler and doesn't list any wheeled 440s. Isn't that the same engine and all? The JD SM2024 carb sevice manual does not list the 440 and it says the TSX-688 fits the 430 tractor and Zenith Marvel Schebler catalog says the same on that carb. Only other place you would find info is in a JD parts catalog. You said it was a 1960 model? The Zenith Marvel Schebler applications charts in catalog made a separate notation listed as I posted above about the gasoline 1960 440 crawler using the Marvel Schebler TSX-777, JD part # ATY20956B which is replaced by the new Zenith 014996 which current new list price is $345.75 and that is from new 2005-2006 price sheet. The number 17A40 doesn't mean anything for a new Zenith ID number.
