3 point hitch slow lift speed on 4440
davepanda
01-02-2006 08:56:53
I have noticed the 3 point lift speed on my JD 4440 has decreased markedly the past couple of years. I used it this Fall to pull a mounted 3 shank ripper. At the end of the field I typically waited about 10-15 seconds for the hitch to lift to the upper-most position. When the tractor is not in use the 3 point hitch does not settle. Also when there is no load on the 3 point it raises at a normal speed. The hydraulics work normally.
macleod
01-03-2006 00:05:54
 Re: 3 point hitch slow lift speed on 4440 in reply to davepanda, 01-02-2006 08:56:53
adjust or replace the stroke control valve in the pump , easy job , they are a wearing part. system pressure needs to be checked
Yelog60
01-02-2006 09:00:03
How are the rest of the hydraulics?? Filters/fluid been changed lately? Maybe a check valve is sticking...
