Got a 4840
farmerboy
01-02-2006 08:38:55
Dad went and sent me to an auction friday to buy a 4840 and Badger 12500 tanker. Got the tractor for less than 13K, lost the tanker at around $6800 (it was in steller condition as compared to the rest of the machinery there. We bought the same number tanker the next day at a dealer for 3K less but with some troubles).
Now Dad's stable includes a 3010D, 3020D, 4020D, 4430, 4640, and 4840. I was hoping for him to find something 4wd, either row crop or articulated (grumble, grumble).
I've been looking through my (too) many books to figure out the difference between our 4640PS and our new 4840. The only difference I've found is the 4840 has 24 more horse, 900lbs more hitch lift, and weighs 2000lbs more with ballast. We parked them side by side and they have the same dimensions. They even have just about the same fuel consumption. Only difference between ours is tires and the 46 has a front fuel tank.
So I ask, is the 4840 basically just a turned-up 4640?
farmerboy
01-04-2006 05:07:04
 Re: Got a 4840 in reply to farmerboy, 01-02-2006 08:38:55
Thanks all for the information. Like I said, none of my books told me those differences. How did you guys know?
JDBert
01-03-2006 14:25:13
Greenjeans is pretty much right on- they are 6 inches longer- a 4840- is a totally loaded tractor- they only came in PS-NO open stations-all had cabs- the only option you had was a 3rd valve and tires and weights options No FWA were made either. GOOD tractors LOTS of them are turning 225+. Oh and the 4640 had a "A" series fuel pump Where the 48's have a "P" series.
green jeans
01-02-2006 20:39:02
Actually they do not have the same dimensions and have several differences. The 48's are longer by about 5 inches to accomadate a larger fuel tank. PTO drive inside is different along with some other drive train differences .Axles are bigger ,alternator is bigger amps,fuel pump is different internally, tie rods are bigger etc-etc-etc. I recently needed a tie rod end and went to the JD dealer who's parts man knows everything off the top of his head and ended up making a trip back to town with the 4640 tie rod end that did not fit the 48. He was just sure they were the same until he looked it up. Any way the others are correct in saying you can not go wrong either way . I have had both and love the power they have.
johndeereboy
01-02-2006 13:23:35
We have two 4840's. One has over 10000 hours on it. Both have had the screws turned on them and have plenty of power. We pull anything from a 5-18" flip-over full mount plow, to a 32' Triple K. It will even handle the 800 bushel Kinze cart on tracks but most of the time you have to steer with the brakes.
yelog60
01-02-2006 08:58:35
We have both a 4640 and a 4840, basically the same unit, our 4640 is a quad range and the 4840 is a powershift. I like the quad transmission better, the ps it too jerky. I personally think our 4640 would out pull the 4840, just seems to run better.. Both have around 4500hrs. We had the injectors and pump redone on the 4640, and it was making over 200hp, not sure on the 4840, never had any work done on it. It gets used to pull a 30ft soiler finisher, does a decent job.. Both good tractors though, very reliable.. You cant go wrong either way..
