Paul: You almost have to have an air leak, a suction leak, at any connection below the input to the fuel transfer pump. You could have a leaky seal on the transfer pump shaft that is allowing air in, or maybe a leaky injector pump, that is allowing fuel to drip out, so that pump looses its prime (I this is not likely). If your 720 has the auto-bleed check valve, could you have a leak there? At this point, if as you say it "ALWAYS" happens, I think I would plumb some air to the filter input and lay 20 psi on it and look for leaking. Use some ether to clean all suspected areas first, as a dirty, greasy, area will make it tough to detect a fuel film. Ideally, you would pressurize a container of fuel and plumb that into the line from the fuel transfer pump (after you eliminate the fuel transfer pump from suspicion) to the filters and look for leaks. Don't forget to look at the line where it enters the fuel rack on the right side of the block. But in the end, the filters are pretty much the low point of the system, so check carfully that there is no rust pit in the bottom of one can that is leaking. Frank
