JD 50 Generator Rewiring
D. Hartzfeld
01-01-2006 18:57:52
I am just completing a restoration on a '53 JD model 50. I never marked the wires when I unhooked them from regulator/generator. I haven't seen a good diagram yet. I just need to know where the white wire goes, and where the black wire goes. (To/from)
Your help appreciated.
John T
01-01-2006 19:36:32
 Re: JD 50 Generator Rewiring in reply to D. Hartzfeld, 01-01-2006 18:57:52
DH, For a 3 terminal (BAT ARM FLD) VR
BAT terminal on the VR wires up to the Load (NOT to battery/starter) side of the ammeter.
ARM terminal on VR wires to the Gennys Armature (may be larger of the 2) post
FLD terminal on VR wire to Gennys Field (may be smaller of the 2) post.
IFFFFF its a 4 terminal VR, it has an extra LOAD terminal, in which case it would feed the BAT input terminal on the light switch to feed loads like lights n ignition.
If theres but one always hot wire down from the dash on a 3 wire VR (BAT ARM FLD) thats the one from the ammeter that wires to the VR's BAT terminal. If theres 2 wires down from the dash, thats usually for the 4 wire VR system where the always hot one wires to the BAT on the VR and the not hot one wires to the LOAD terminal on the 4 wire VR.
Clear as mud???
John T
D. Hartzfeld
01-02-2006 11:13:54
 Re: JD 50 Generator Rewiring in reply to John T, 01-01-2006 19:36:32
MY Voltage Regulator Has 3 Terminals.
There are 2 wires that run directly from the voltage regulator to the rear of the guage panel. I think I understand the one wire runs from "Bat Term" on the generator to the ammeter terminal that doesn't contain the wire comming up from the starter. Correct?? I need this in basic, basic terms. So where exactly does the wire that comes from the other post on the voltage regulator connect to???
Thank you for your help.
ONe of the 3 side terminals on the VR Connects to the generator. There is also another wire running from the underside of the VR to the other post on the generator. This lets open the other 2 side terminals which are connected to somewhere up front.
John T
01-02-2006 17:00:18
 Re: JD 50 Generator Rewiring in reply to D. Hartzfeld, 01-02-2006 11:13:54
DH, Now with that new info you just gave me I can pretty well say for certain YOU HAVE A 4 POLE VR. On those, the 3 all lined up are BAT FLD LOAD while the one underneath or off on a side all by itslef is the ARM terminal.
There are 2 wires down from the dash. Put a test lamp on one and the ones thats ALWAYS HOT wires to the BAT terminal on the VR. The other wire down from the dash NOT HOT wires to the LOAD terminal on the VR. It wires up to the switches BAT input terminal to provide voltage for Lights n Ignition
On the VR
BAT wires to the hot wire from the dash FLD wires to the gennys Field post LOAD wires to the NOT HOT wire from the dash ARM (the wire underneath) wires to the gennys Armature post
John T
55 50
01-01-2006 19:07:39
According to the diagram in my copy of the John Deere Electrical Systems book, the white wire goes on the BAT terminal. That same diagram doesn't show a black wire at the gen/VR. It just has the two short wires from the VR to the F and A terminals on the gen body, center VR term to A gen and end VR term to F gen.
