5020 oil in coolant
nick in Wi
01-01-2006 18:55:33
My uncle has a 5020, i don't know to much about it other than it has about 7000 hrs on it. He is getting oil inside the coolant but not coolant in the oil. What could be the problem? head, sleeves, bad gaskets, just wanna hear what you guys think. thanks Nick
buickanddeere
01-01-2006 19:44:36
 Re: 5020 oil in coolant in reply to nick in Wi, 01-01-2006 18:55:33
Run oil analysis to see if coolant is or isn't getting into the engine oil. Test the coolant with the Deere three way test kit. Odds are the coolant is old enough to vote and has gone acidic. This allows the wet sleeves to pit through. Could be lucky and just have a head gasket corroded through.
msb
01-01-2006 20:20:39
 Re: 5020 oil in coolant in reply to buickanddeere, 01-01-2006 19:44:36
Could also be the oil cooler,but Buick& Deere is probably correct.Remember the oil pressure runs higher than the water pressure so a pitted sleeve isn't the problem if there is no coolant in the oil.
buickanddeere
01-02-2006 14:50:42
 Re: 5020 oil in coolant in reply to msb, 01-01-2006 20:20:39
I thought of the oil cooler today at work but couldn't post until now. They suspended my internet rights at work.
