Carb Tuning on 44 B
CalJim
01-01-2006 18:11:48
Hello,
Tuning in the carb on my B, idle needle adjustment went fine, my manual says I
need to put a load on tractor to adjust
load needle.That certainly makes sense
but I have no way to put a load on the
tractor.(At least I can't think of a way)
Can anyone help on this one? Thanks, CalJim
I also have another problem....
This tractor is a 44 BW long hood with the cast dash, and the speed control
lever is extremely hard to push back and
forth. I pulled the cotter pin and let
the spring & washer down to the housing
but now the lever creeps back by itself,
the spring is not compressed enough to
hold the linkage.
DickD
01-02-2006 00:14:31
 Re: Carb Tuning on 44 B in reply to CalJim, 01-01-2006 18:11:48
I'm sure somewhere around you there is a power show that will have a Baker fan. The people that put on the show are generally more than happy to help you belt up to it. It will definitely put a load on your tractor.
Duane Larson
01-01-2006 18:40:21
CalJim,
A couple of ways come to mind. If you can locate someone with a dynamometer that would be the ideal way. It is driven off the PTO, and can load your engine and allow tuning of the load circuit and timing. Often dealers have them, or they are a popular item at shows here - owners hook their tractors to the dyno and see how they do. We have one at our show which is hooked into a laptop and with software allows calculation of a torque curve.
If you have access to a larger tractor (a G or D would work) with a belt pulley, and a drive belt, you can belt your tractor to the larger one, and use your engine to drive the other one against its compression pressure generated by spinning the engine over. It will have oil pressure, so no harm is done, and while it is not a very adjustable load it may be good enough to set your load needle.
old
01-01-2006 18:17:22
As far as the carb its one of those things where you drive it and do your best to get it running the best you can. Hills, pulling something etc will help. Shoot hook a chain to it and your car/truck and pull it and adjust it till you feel you get the most HP out of it that you can.
