720D Camshaft
Kevin L.
01-01-2006 16:24:28
the parts manual list a part to go with the camshaft for serial no above 7223364 as a AR20874R fuel bleed, have not look at jd online parts yet, but wanted to know if someone could tell me what this part replaces or where it goes, the 720D I working on has a bad place around the key and I need to replace the camshaft and was thinking of replacng it with a 730D if I could understand where the other part goes and the 730D I think has the anti-run backward.
F-I-T
01-01-2006 17:22:01
 Re: 720D Camshaft in reply to Kevin L., 01-01-2006 16:24:28
Kevin:
If you go to page 35-10 of your parts book, it calls the AR20874R a "Fuel Bleed System". This, I believe is the (unpictured) collection of plumbing, tubes, and the valve that allows for self-bleeding of the diesel system. I wish I had more info than that, but if it were me, I'm pretty sure the 730D camshaft will work, but it will not self-bleed unless you install the "stuff" called out on page 35-10.
Wish I had more to offer.
Frank
Kevin L.
01-01-2006 19:11:26
 Re: 720D Camshaft in reply to F-I-T, 01-01-2006 17:22:01
also see it shown on page 35-14 and guess it's an addon to the pressure relief value. a picture from someone with a 730d would help.
Think the only differents in the 730 and 720 camshaft is shape of the lobe for the injector pump to inject at a different timing spot when the engine tries the run in the reverse direction. just read the lobes where different somewhere and put 2 and 2 together but have not seen a 730 camshaft to know.
would you replace the cam bearing when replacing the cam, jd only list the right bearing and any hope of get cam reworked or go to salvage and shell out the green.
thanks frank and others who may reply..
F-I-T
01-02-2006 05:11:18
 Re: 720D Camshaft in reply to Kevin L., 01-01-2006 19:11:26
I would measure the bearings and if they were in service limits, I'd leave them alone.
Frank
Mike M
01-01-2006 21:23:16
The late 720 should also have the same cam as a 730. What's your ser. # ? I think the other parts you mention is the valve that goes in the fitting into the top of the pump cover and your return line hooks to it.
Kevin L.
01-02-2006 05:44:56
 Re: 720D Camshaft in reply to Mike M, 01-01-2006 21:23:16
it's in the 72154XX area, just can't remember off the top of my head.
