John Deere Model B Gearshift
Al Simmons
12-31-2005 11:51:21
Just got a Deere Model B to fix up and ran into gearshift problem. Difficult to get into gear and then will be in different gear than indicated on the gear box; for example, when in second gear, it runs like it's in sixth gear. The gear shift lever is very loose and will move up and down too much. What am I in for in fixing this? Al
Mike M
12-31-2005 15:15:30
 Re: John Deere Model B Gearshift in reply to Al Simmons, 12-31-2005 11:51:21
May end up being as simple as pulling the top of the tranny and fixing the gear shift lever so it stays up against the spring pressure.Then move the shift forks around with a crow bar make sure they work then place them all in neutral and put the top back on.
Al Simmons
01-02-2006 12:57:18
 Re: John Deere Model B Gearshift in reply to Mike M, 12-31-2005 15:15:30
Thanx for the info. I hope this is all it takes. Al in Tennessee
Al Simmons
01-02-2006 12:56:40
Thanx for the info. I hole this is all it takes. Al in Tennessee
