3020 syncro trany hard shifting
Randy Bouman
12-31-2005 09:34:23
My 3020 has started to shift very hard in all the sections of the shifter. The clutch pedal travel is adjusted properly. To go from 5th to reverse or from reverse to 5th takes a lot of jerking and pressure to get it to move. When the trans goes from reverse to a forward gear or from any gear to neutral the tractor will rock a little as if there was pressure on the trans. I thought it was the clutch but now I don't know. Before I split the tractor to replace the clutch has anyone had this before?
Randy Bouman
04-04-2006 15:18:26
 Re: 3020 syncro trany hard shifting in reply to Randy Bouman, 12-31-2005 09:34:23
New clutch is in and new pilot bearing and throw out bearing. All forwrad gears seem to shift great. Into both reverses is a little difficult and out of both reverses is more difficult. With a good jerk it comes out but it ain't right. Any suggestions?
Randalp
01-03-2006 14:52:03
try shifting when engine off. If it shifts easier, then you know its input shaft is turning when clutch released for whatever reason. If its just as hard, running or not, check your linkages
donmyeil
12-31-2005 12:32:03
sounds like the clutch disk and/or the pilot bearing is dragging. Is the adjustment bolt at the top of the slot? If so then the clutch is abt done anyhow.
Randy Bouman
12-31-2005 17:15:49
 Re: 3020 syncro trany hard shifting in reply to donmyeil, 12-31-2005 12:32:03
Yes, the adjustment is about gone. The clutch does not seem to slip during use. I thought the clutch would slip when it was bad. If the clutch is the problem. Why won't the clutch disengage? I appreciate your help. Thanks for your response.
donmyeil
01-02-2006 14:28:03
 Re: 3020 syncro trany hard shifting in reply to Randy Bouman, 12-31-2005 17:15:49
the splines get worn and /or rusty causing the disk to hang up. also the drive pins for the pressure plate get rusty and worn and not moveing far enough. also some warpage of both plates as well. hope this helps. Don
Randy Bouman
01-04-2006 16:06:12
 Re: 3020 syncro trany hard shifting in reply to donmyeil, 01-02-2006 14:28:03
Thanks for the info. Got the tractor blocked up and the bolts broke loose. She should come apart this weekend. Thanks again for the help. RJB
