Friends JD 430 Battery Drains while tractors sleep
Wayne from Iowa
12-31-2005 05:14:31
My friends 430 battery slowly goes dead with everything shut off. What should I check for besides bare wires??. Might not take so long to find the trouble if you guys would give me a checklist. Thanks for any help.
Ray
12-31-2005 13:12:26
 Re: Friends JD 430 Battery Drains while tractors s in reply to Wayne from Iowa, 12-31-2005 05:14:31
If it has bare wires it would already be burned up or you would see sparks,most of the time it's just an old rusty voltage regulator that sticks.
John T
12-31-2005 17:45:55
 Re: Friends JD 430 Battery Drains while tractors s in reply to Ray, 12-31-2005 13:12:26
Ray, for sure, the cutout relay contacts in a rusty old VR can stick, that will run down the battery pretty quick plus his genny would feel hot. Ive seen guys tap them with a hammer but by then they are pretty well done for lol
Happy New Year
John T
John T
12-31-2005 08:59:05
Wayne, before putting the tractor to bed remove either battery cable n see if she still discharges, if so its a battery problem instead of a short. Inspect the battery n see if theres electrolyte above all the plates and that no cells exhibit a gray or milky color, cuz it may have a bad cell thats causing the slow discharge. In the event when the tractor was shut off there were a heavy discharge reading at a working ammeter, it may well be a sticking cutout relay and that would also make the genny get hot but would run the battery down fairly rapidly.
Take a look at Franks good troubleshooting procedure n try that and follow our discussion about WHICH battery cable to remove maybe.
John T
F-I-T
12-31-2005 07:51:50
Wayne:
The easiest way to find a short on any car/tractor/DC system is to find a light bulb or an old car door keys-in-the-ignition-buzzer for that voltage or greater. If you can have a few bulbs on hand it's better in case you pop one. Or, use an old car headlamp.
1) Start with a charged battery
2) Turn all switches to off
3) Remove just one of the battery cables for the test.
4) Using some suitable alligator clips, attach the test lamp/headlamp/buzzer between the battery post and the loose battery cable. If the light glows you have a current drain. If not, the system if fine and your battery is probably suspect.
5) Leave the test lamp connected and perform a general inspection of wiring to see if you have any bare metal connectors or bared wiring touching the chassis. If at any time the lamp goes out, you have found the short to ground.
6) If the lamp still glows, move to the dash switch and try to find the wire that runs from the battery to the switch, or maybe it runs from the hot starter connection. This is what feeds everything (ignition/lights/etc.). If you remove this wire and the lamp goes out, you need to remove every wire under the dash, again one at a time.
7) Now move to the generator/cut-out/voltage regulator wires. Remove wires again, one at a time, each time looking to see if the lamp went out.
Now, once again, if you remove a wire and the lamp goes out, you have found a short to ground condition, and you need to fix that before you move on. While it is easiest to replace the wires after you disconnect them, understand that if you have two or more shorts, you might miss an offending wire and have to go through them again.
Frank
John T
12-31-2005 08:52:15
 Re: Friends JD 430 Battery Drains while tractors s in reply to F-I-T, 12-31-2005 07:51:50
Good Morning Frank, Lets discuss your troubleshooting procedure a bit, I intend this as a friendly discussion as we always have to hopefully learn from each other or help the poster, NOT argue.
1) Where you say to "remove ONE of the battery cables" shouldnt that say to remove the UNGROUNDED BATTERY CABLE????? ????? ?? In a minor short that drains the battery, its often cuz a wire has faulty insulation and its in contact with the frame somwhere. If you remove the UNGROUNDED cable, place one end of a tester to the hot unattached battery post, and probe with the other test lead, when you find a circuit that is shorted to frame, then the lamp glows right????? HOWEVER if you removed the other battery cable, attached the lamp to that unatached battery post and began probing wires looking for a short, any wiring ahead of any good switches will cause the lamp to glow correct, cuz thats the same as the test lamp being right across the battery.
Of course, you and I likely use shortcuts when trying to help someone cuz we assume some basics and cant use extreme detail to point out every lil step, or our post would get too long. SO DO YOU AGREE ONE SHOULD REMOVE THE UNGROUNDED BATTERY CABLE and if not and either will work, please explain, I havent thought this out all that hard just yet, its my first impression and Im open to be educated. I agree regardless what post if the lamp glows theres curent draw, but if one is probing around looking for ground paths it seems we ought to tell the poster to remove the battery cable to the ungrounded battery post.
2) Same as you, I have used the test lamp or buzzer method and also described it for others looking for a short. HOWEVER I dont think its the best test method and why I usually use my old reliable analog Simpson 260. The reason being, if theres a minor high resistance short, some test lamps or some buzzers may not glow or buzz, HOWEVER the Simpson would still indicate Voltage, the higher the voltage the worse the short agree??? I think most test lamp testers use very low wattage bulbs (i.e. very low current requirements for glow) and if the shorts even a high impedance it would still glow but Im afraid many buzzers take more current????
Talk n think with me !!!!! !!!
John T
F-I-T
12-31-2005 09:07:08
 Re: Friends JD 430 Battery Drains while tractors s in reply to John T, 12-31-2005 08:52:15
third party image
John:
Maybe I was in too much of a daze with my cold medication (I have been house bound for my whole week off), but the gist is that you remove one calbe and insert the lamp IN SERIES with the battery post and the removed cable. If current is flowing, the lamp will light or the buzzer will buzz.
Ground cable or hot cable, it's still a circuit. Right?
dieselade
01-01-2006 02:51:28
 Re: Friends JD 430 Battery Drains while tractors s in reply to F-I-T, 12-31-2005 09:07:08
to add to my confusion , why did you use a picture showing a positive grounded battery when 99% of all tractors and neg ground????
John T
01-01-2006 06:52:12
 Re: Friends JD 430 Battery Drains while tractors s in reply to dieselade, 01-01-2006 02:51:28
Good Mornin n Happy New Year Diesel, 100% of the two cylinder John Deeres were factory original Positive grounded along with many tractors of similar vintage of other brands as well. In the sixties and later and especially when many tractors switched to alternators, then Negative ground became the standard.
Take care n God Bless
John T
John T
12-31-2005 11:10:02
Wish I could post them pretty diagrams, a pictures worth a thousand words Eh??
YES its still a circuit n if the lamp glows theres a short I AGREE WITH YOU. BUT AFTER YOU KNOW THERES A SHORT, Its just that to trace n hunt down which circuit, isnt it better to remove the ungrounded battery cable and probe around looking for the "ground fault" (the wire/circuit thats shorted)?? If you remove the ungrounded cable and attach the tester to the bare battery post and touch over to the other battery post she lites up a full 12 volts, but when you probe around other wires n circuits the glow will be less bright depending on how much resistance there is in the ground fault. STILL, when you find a wire that lites the lamp, you found the SHORT. That shouldnt be so unless youre direct to like the lights or coil etc but even the circuit to them ahead of the switches shouldnt lite the lamp UNLESS theres a gorund fault (which is what youre lookin for in the first place)
BUUUUTTTTT TTTTT if you used the other grounded battery terminal and unhooked the ground cable n attached the lamp to that terminal n probed around with the other lamp lead, whats going to lite the lamp is wires/circuits that are connected to the other hot ungrounded battery cable n post, i.e. any circuits tied to the ammeter ahead of any switches that are OFF. If you do it that way the things that lite the lamp are wires that SHOULD LITE THE LAMP but youre posed to be probing n looking for wires that are incorrectly shorted to frame right????
I agree EITHER post will work to preliminarily see if theres a short and thats what you told the poster and it works indeed. I just argue (in our friendly manner) that once you know theres s ground fault, you ought to be probing between the bare ungrounded battery post (i.e. remove the cable to starter etc) lookign for what wire/circuit indeed is providing the ground short cuz its that "to ground" short thats the problem.
My first wife n daughter both have a cold also but not me so far (knock on wood) Drink some spirits n get a good sleep n think on it n see if you agree?????
John T
F-I-T
12-31-2005 13:38:24
 Re: Friends JD 430 Battery Drains while tractors s in reply to John T, 12-31-2005 11:10:02
John:
I've posted that picture so many times I've lost count, and you were in on the thread when it was posted most times. I'm a little surprised it's a cause for such consternation with you now.
This is the circuit that I have used to success for many years, and it involves no probing; just wire removal. As far as unhooking the ground cable and moving it around to find the "ground fault", most of these tractors have a single connect point under the dash for hots, and one other at the voltage regulator. Just how many "ground faults" can you find that will isloate a single component? My guess is not vey many. Your way will work well when you think you have a ppor ground, but I've never seen those drain a battery down.
I'm betting this will work well for Wayne, but if doesn't perhaps he can find something a bit more complicated.
Frank
John T
12-31-2005 15:45:15
 Re: Friends JD 430 Battery Drains while tractors s in reply to F-I-T, 12-31-2005 13:38:24
Thanks for the fun discussion Frank, I dont recall that pic before but still like it. I guess we can agree to disagree on this one and thats no problem for me nor I suspect you either.
If you remove the battery from the conenction to frame ground (by removing the grounded connection versus the ungrounded one), however, I dont see a good way to use a test lamp to probe wires n circuits trying to find whichever one has a ground path which is whats runnin down the battery and what hes looking for. If theres a wire/circuit that has bad insulation rubbing against the frame, THATS WHAT DRAINS THE BATTERY and is the same wire/circuit that causes his test lamp to lite (if connected per my plan) so I would use that test method n whatever wire lit the lamp is the source of the short to ground!!!
If he removes the grounded battery cable, however, and attaches his test lamp to that bare battery post and starts probing for wires that make the lamp glow, any wires/circuits that are hot n fed from the ammeter or the LOAD terminal on a 4 wire VR are GONNA LIGHT UP, HOWEVER when using my method a wire that has a ground fault is gonna light the lamp and that (a shorted wire) is what hes lookign for, i.e. a shorted path to groundthats draining his battery.
Anywho we can friendly disagree, but if he wants to use a cheap test lamp to find a shorted circuit (glows when he finds it) I maintain HE CAN NOT remove the battery connection to frame, but must instead remove the ungrounded connection, then the test lamp will glow when he finds the short, cuz the other battery terminal is tied to frame ground and the lamp circuit is complete BUT NOT IF YOU REMOVE ANY CONNECTION TO FRAME!!!!! !!!
We disagree I reckon, but this would be a boring world if it were othewrwise lol.
Happy New year Frank n God bless yall
John T
F-I-T
12-31-2005 16:03:53
 Re: Friends JD 430 Battery Drains while tractors s in reply to John T, 12-31-2005 15:45:15
John:
You understand that in "my" arrangement, you let the lamp connected all the time while you remove one wire at a time until the light goes out. So....the last wire you removed contains the drain to ground. There is no "probing".
When you said "If he removes the grounded battery cable, however, and attaches his test lamp to that bare battery post and starts probing for wires that make the lamp glow, any wires/circuits that are hot n fed from the ammeter or the LOAD terminal on a 4 wire VR are GONNA LIGHT UP, HOWEVER when using my method a wire that has a ground fault is gonna light the lamp and that (a shorted wire) is what hes lookign for, i.e. a shorted path to groundthats draining his battery.", I wondered out loud "So what's the difference?" You can even use the hot post in "your" scenario because the lamp would light when you touched a hot connection that was leaking to ground as well. I though my explanation was a helluva lot simpler for a guy who asked for a step by step procedure.
I unhook a wire to find the path to ground, and you probe for it.
I'm going to let this drop as I'm sure Wayne has probably given up on this thread being of any help by now.
Frank
John T
12-31-2005 17:41:19
 Re: Friends JD 430 Battery Drains while tractors s in reply to F-I-T, 12-31-2005 16:03:53
I hear that lol We probaly have poor old Wayne so cornfused by now hes given up. But at least we can have a lil fun n maybe learn a trick er two along the way.
Happy Newy Year n God Bless yall out there
John T
Hayfarmer
12-31-2005 07:38:25
Are you sure the battery is being Drained and not just loosing power? I would start by pulling the ground wire off, hold it close to the battery terminal it came from and see if there is an arc. If there is they there is a drain somewhere. Start by isolating different parts, really not too much on 430 that draws current, just ignition system and lights. All the electrical stuff(except starter) goes through the switch, at least if still 6 volt.
Johnnyputt
12-31-2005 07:18:27
Check to make sure the points in the voltage regulator are seperating at low idle and prior to shutdown. If not slightly adjust the spring tension on those contacts until they release at low RPM's.
chidog
12-31-2005 05:42:33
Has this tractor been converted to 12 volt?
jd40
12-31-2005 18:34:38
 Re: Friends JD 430 Battery Drains while tractors s in reply to chidog, 12-31-2005 05:42:33
Wow, I got A headache now if it is 12v ,I have seen where people wire the one wire alt. with the one wire to the battery and the main lug on the alt. and they will run a secound wire to the regulator prog this wire they will run it to a constant hot which will drain a battery , just put it to the switch . maybe that will help ,good luck
chidog
01-01-2006 06:58:00
 Re: Friends JD 430 Battery Drains while tractors s in reply to jd40, 12-31-2005 18:34:38
A true one wire alt will have onle one wire, from the alt to the battery. That's what whould be used on all 12v conversions.
jd40
01-01-2006 08:59:13
 Re: Friends JD 430 Battery Drains while tractors s in reply to chidog, 01-01-2006 06:58:00
Yes that is true ,and race to motor up to start it charging,but all the one wire alt I have purchased or came across have regulator inside with the two prongs and a rubber cap over them,and some of the tractor will have a single wire running to one the prongs from the battery side of coil,so went the motor starts it kicks on the alt.and if that wire is ran to the battery it will drain it .right or wrong I do not know but it works .would not be the first time I was wrong about somthing.
chidog
01-01-2006 11:53:04
 Re: Friends JD 430 Battery Drains while tractors s in reply to jd40, 01-01-2006 08:59:13
A one wire should not have any wires running over to the prong(s). If any of those wires (from the prong) is energised when the tractor is not running, the battery will be drained unless it's unplugged or a switch is installed in the circut.
