3020 radiator
anderson farms
12-31-2005 00:14:54
Know a good place to get a JD radiator besides deere? Mine is leaking in the bottom and the pipe on the side is leaking also. I have a 64 diesel, are they to bad to change? Thanks for all the help
msb
01-01-2006 16:40:05
 Re: 3020 radiator in reply to anderson farms, 12-31-2005 00:14:54
Drain the radiator.Remove the hood,hoses ,steering line clamps,two brace rods ,three screws on each side holding the shroud in place.Push the shroud back as far as it will go.Remove the 2 bolts holding the bottom of the rediator in place and then roll the radiator out on the left side of the tractor.Don't lose the rubber pads the radiator frame sets on or the canvas pad that goes under the hydraulic lines on the right top of the radiator.
Dingaling
12-31-2005 17:33:16
Shoup has them @358.00. Replaces AR46016, AR40831, R34457, Probably the cheapest you will find. I got one several years ago, quite a bit cheaper then. It seems to be holding up well. Of course the first one lasted 35 years.
Jack-Iowa
12-31-2005 14:23:49
Local radiator shop should be able to get.Got mine there and not hard to remove at all.
