Clutch hung up on Model B
Earl Parkerson
12-30-2005 18:22:18
I have a 1949 Model B which I can not get the hand clutch to disengage. Do any of you know where I need to start looking on this? Is it linkage or clutch plates welded together? I have not done any work on it yet and was wondering if anyone has had this same problem.
Lucas M
12-31-2005 09:01:45
 Re: Clutch hung up on Model B in reply to Earl Parkerson, 12-30-2005 18:22:18
I had the same problem with my AR and I ended up taking the pin out that moves the clutch brake pad. Then I put it back together and it work sometimes you just have take it apart and get it broke loose.
Mike M
12-30-2005 20:32:40
I guess I'd start by taking off the cover and loosening up the adjusting nuts. Probabaly end up taking out the clutch plates cleaning up everything and also make sure the bolts move freely in the pulley.
Wayne H
12-31-2005 15:22:00
 Re: Clutch hung up on Model B in reply to Mike M, 12-30-2005 20:32:40
my 49 B clutch gets stuck every once in a while. I turn it off, make sure I have a clear shot, put it in gear and start it up with the clutch "disengaged" but stuck. Whatever the issue is, it seems to free it up and be just fine.
Wayne
www.flymha.com
