1950 A fanshaft
Eli
12-30-2005 17:41:42
I'm putting my fanshaft back together with new bearings, o rings, seals, and gaskets. It has a ventalater pump. Is there a proper order to assemble it? I was going to assemble the pump end first. Then slip on the internal seal, spring, bearing and outer seal. Finish by putting on spring, clutch, fan, clutch, collar, and keeper. Does this sound like it will work? Any advice appreciated. Thank you, Eli.
Mike M
12-30-2005 20:36:16
 Re: 1950 A fanshaft in reply to Eli, 12-30-2005 17:41:42
Sounds like how I've done them. After I put the pump together I put some temperary bolts through it to hold it together and keep the gaskets in place.
Eli
12-31-2005 10:46:14
 Re: 1950 A fanshaft in reply to Mike M, 12-30-2005 20:36:16
Thanks Mike, I'm about ready to give it a shot.
