AR v. R
jdkid1952
12-29-2005 18:59:57
i was starting to get the feeling lately that i knew a good bit about antique john deeres. apparently not. i got a few two-cylinder books for christmas and as i was flipping through one of 'em when someone leaning over my shoulder asked me what the difference was between the "AR" model and the "R" model. i knew that they were produced different years and i thought the AR was based more on the A and i knew that the R was the deisel. are there any other noticable differences between them (besides the decals) that would help identifying them from each other? that's all i got, thanks.
dane
DickD
12-30-2005 03:36:12
 Re: AR v. R in reply to jdkid1952, 12-29-2005 18:59:57
JDkid; The quickest way to distinguish the R and AR apart is the exhaust pipe. On an R the exhaust is behind the air cleaner intake, and on an AR the exhaust is in front of it.
dab
12-30-2005 00:44:35
Stand beside one and you will insantly know the difference. Completely different tractors, major horsepower difference. 2 or 3 bottom plow with a ar. 4 or 5 maybe 6 small ones with a "r". Stand beside them, can put your arms on top of a "ar" and talk to the guy on the other side. Can bend down a little and talk to that same guy thru the engine opening on a "r". Also roughly 3500lbs difference too.
F-I-T
12-29-2005 19:41:20
I guess the easiest way to explain it is that the "AR" is a standard tread version of the "A", and the "R" is the standard tread version of the "R". The "R" was only ever offered in the standard tread and only as a diesel, while the "A" and "AR" were offered in All-Fuel, and then later gasoline engines, never a diesel. The "R" was really an outgrowth of the Model "D" chassis into a diesel tractor. Now that's kind of being sloppy with the evolution, but it'll get you close.
Frank
