3020 Carb.
Paul Silseth
12-29-2005 18:50:50
I have been reading about the carb problems. My 3020 will not start now without starting fluid whether it is hot or cold doesn't matter.
The carb I have is Marvel Schebler, Model:USX and part #: USX 36 and then stamped on another area is 66L Where do I go to get a zenith if that is what is recomended. New or rebuilt? What is the going price? With my mechanical ability I will also have to hire it installed. It's a pain but is there any hurt in just keeping a can of starting fluid in the tool box and using that each time, or is my engine running poorly and I just don't know it (my ignorance is showing isn't it)
Serial # on the enginge block is 11E100066 Can anyone tell me how old and the HSP with that info?
Thanks Paul
Glen in TX
12-30-2005 11:51:46
 Re: 3020 Carb. in reply to Paul Silseth, 12-29-2005 18:50:50
Paul, From what I read on other board about your carb I thought you had already tore into it checking it out. Apparently not so ask around in your area to find out who has rebuilt the MS USX carb before and willing to do so. Find a mechanic who knows that carb and your tractor well or you most likely won't get it rebuilt right or find out if it is rebuildable. Just depends on if something is really wrong with carb or what other problems you have and a good local mechanic can find those problems for you without spending more just changing parts. I like the Zenith carbs because you can get them new when the other carb fails completely. There were bad Zeniths made too but in this case the Zenith is just a better design it seems. Good luck, Glen
Mike M
12-30-2005 04:31:42
I'd say you have other problems. I'm not a big fan of the MS carbs. But the troubles I had with them was off idle acceleration and mid range.They seem to not regulate the mixture right and run rich.
J. Schwiebert
12-30-2005 04:13:37
Boy how I agree with you on your comments on the Marvel USX carburetors!
msb
12-29-2005 20:09:05
Might not be the carburetor at all that is at fault.Since you would have to have someone install the Zenith,hire someone to properly diagnose the tractor.It could be as simple as readjusting the choke cable .The choke might not be fully closing.Could also be that the engine needs a good tune up ,but the first place to start would be a compression check.Your tractor may be in need of a valve grind.Then check the plugs and points as well as the timing and timing advance.If the spark plug boots are hard then replace the spark plug wires.Hardened boots will rob the spark somewhat.Another place that should be checked is the manifold gasket and/or vacuum check.
Granted the Zenith carb is a better carb,but the Marvel Schebler carb isn't as bad as it is made out to be here at YT.They get blamed for all kinds of problems not even related to the carburetor.It simply takes someone who understands them and knows how to fix them anyway.
A new Zenith will cost you in the neighborhood of $550 .A rebuilt one with exchange,around $300-$350
Deere parts still show a kit for your Marvel Schebler,but if anything is wrong with it,I would guess it is only the accelerator pump diaphram and they cost very little to replace.
