4020 Steering arm slop
jimjo2
12-29-2005 15:21:17
Does anyone have a fix the slop that develops on the spline between the steering arm and the knuckle on a 4020? I have a fair amount on the right side only??? I would suppose the arm is the part that is worn but I'm not sure.
Jim
jd @ antique acres
12-29-2005 20:15:52
 Re: 4020 Steering arm slop in reply to jimjo2, 12-29-2005 15:21:17
I had the same problem also on the right side. I replaced the steering arm and that tighten things up alittle, but there still is some slop. I am afraid that completely cure the problem the knuckle may also need to be replaced. Seems like once you have wear on the splines it is tough to keep "em tight.
Jim in AK
12-29-2005 16:40:58
Jim,
I got a 4010 and there was a lot of slop in the right side. I replaced all 4 rod ends and ALL the slop went out. They were all bad but the right side outer was the worst.
Keep em greesed.
Jim
jimjo2
12-29-2005 18:06:33
 Re: 4020 Steering arm slop in reply to Jim in AK, 12-29-2005 16:40:58
This is not rod end slop, it is slop in the spline connection between the steering arm and the knuckle (JD's term for the axle assembly).
Jim
Kevin Smolkowski
11-01-2006 10:04:36
 Re: 4020 Steering arm slop in reply to jimjo2, 12-29-2005 18:06:33
I have the same issue, can you shim up the splines and make it work.
