JD 1937 Model A Engine Oil
Silas Green
12-29-2005 14:59:42
I"m new at this antique tractor game and know you experts have an answer to my question.
I recently purchased a 1937 unstyled model A. All of the manuals I have read say to use a "High Quality" Oil in the Engine. Oils have changed over the years, so my question is "What Brand, Weight, Grade (SAE) oil do you old model JD owners use in your antique tractors. Would you use a multiweight, e.g. 10W-30 or 15W-40? Thanks for your expert advise.
Silas Greene
12-30-2005 11:41:37
 Re: JD 1937 Model A Engine Oil in reply to Silas Green, 12-29-2005 14:59:42
Thanks to John In IN, F-I-T, old, and DickD for you insite on the oils. Unless someone runs up a red flag I think I will use Chevron DELO 400, 15W-40 or Shell Rotello, 15W-40. I use these oils in my Massey and trucks.
F-I-T
12-30-2005 14:18:53
 Re: JD 1937 Model A Engine Oil in reply to Silas Greene, 12-30-2005 11:41:37
Both great oils. I use Rotella in my 855, 70D, "H", cars, etc.
John in IN
12-29-2005 19:30:44
I run 15-40 in my '37 A and 20-50 in my '37 AR. The AR's oil presure runs a touch low and the 20-50 is just right for it. I do run these in the winter too. There are many opinions on this subject and most are valid.
Good luck and a Happy New Year.
F-I-T
12-29-2005 19:47:42
 Re: JD 1937 Model A Engine Oil in reply to John in IN, 12-29-2005 19:30:44
John:
You're really right on that. Let's face it. The oils today are so much better than any oil from 60 years past, and most of these tractors get so babied that just about any modern that is clean and changed regularly is far better than their everyday treatment in 1940.
Just use a weight that you like and change it often and you'll be treatin her like she never expected.
Frank
old
12-29-2005 15:08:05
Well in my 1935 JD-B I still use the stright weight oils and also use what is called for as far as the weather. I.E. if its in the summer I use a 40W or 50W oil. I use valvoline raceing oil, right now it has 50W in it but I also don't run it much if any this time of year.
DickD
12-30-2005 01:33:45
 Re: JD 1937 Model A Engine Oil in reply to old, 12-29-2005 15:08:05
Right on Old! When most of these tractors came out, multiviscosity oils were unheard of. Most used a straight 30 weight, due to such large bearing tolerance, and got along fine.
