46 B Reduction Gear Cover
Tractor Dan
10-27-2003 04:46:09
I broke the ear off for the clutch lever. The cover seems to be hung on the aft gear bearing. Any suggestions? Should I replace of weld once I get it off?
johndeereyellow
10-27-2003 07:20:45
 Re: 46 B Reduction Gear Cover in reply to Tractor Dan, 10-27-2003 04:46:09
Tractor Dan: Depends if you want orignal look or not. I did the same thing one time and I see other postings of the same thing. I machined off the broken side of the gear housing and machined a part to look like the part that was broken off. I than mated it to the housing hnd used counter sunk screws from inside the housing up into the machined part. These screws use allen wrench and they are hard. Put them in with a good loctite and they will not back out. Been this way thirty years now and no trouble
