JD 40 Serial Number Location
Ralph - Ohio
12-28-2005 18:58:21
I apologize for asking such an elementary question. My nephew recently got a 40 Utility tractor and can't find the serial number. Can someone tell me where it should be? I found information on the web about where to find the block number but can't find anything about serial number location. Thanks in advance for any help.
jCarroll
12-28-2005 19:20:18
 Re: JD 40 Serial Number Location in reply to Ralph - Ohio, 12-28-2005 18:58:21
The casting between the block and the transmission is called the torque tube. The clutch is inside the big end - against the engine.
The serial Number plate is on the left side of the torque tube, just where the big part necks down. Under the sediment bowl.
There is a place on the torque tube cast into the tube where the plate goes - its about 1" high, and 3" long. If you find this area, and no plate - it's gone.
Ralph - Ohio
12-29-2005 08:33:26
 Re: JD 40 Serial Number Location in reply to jCarroll, 12-28-2005 19:20:18
jCarroll, thanks very much.
