JD 2440 Fuel Problems
Carl Ernst
12-28-2005 18:04:57
My 2440 stalls after 30-60 seconds of running. It will restart but stalls again. I've changed fuel filter and drained about 1 gal from bottom of fuel tank. After bleding the lines at the fuel filter the filter does not fill completely. There remains a small void of fuel in the lower and upper chambers. The tractor still stalls. Although the fuel pump appears to pump ok, I'm in the process of replacing the pump. Someone has told me that the tractor could have lost its prime. I have a JD repair manual and find no reference to priming. Could someone give me advice on my problems and if you think it is a priming issue how do I reprime the fuel system?
jd plowboy
12-29-2005 07:27:37
 Re: JD 2440 Fuel Problems in reply to Carl Ernst, 12-28-2005 18:04:57
check all your return lines. i had a 4010 that would run a few seconds and shut down but would crank right back up. found out that one of the return lines was plugged up. changed line and run find.
Tx Jim
12-29-2005 03:48:09
Carl,remove fuel return line from inj. pump,also remove fitting from pump that return line attaches to,see if rubber chunks are wedged inside fitting. Try to start with fitting disconnected and if engine runs you found your problem. Tx Jim
cannonball
12-29-2005 04:47:24
 Re: JD 2440 Fuel Problems in reply to Tx Jim, 12-29-2005 03:48:09
tx jim is right on the money inj pump needs rebuild....have nice day may god bless
Carl Ernst
12-29-2005 04:44:28
Thanks TX Jim,
I will perform these tests as soon as the new fuel pump arrives. If I see rubber chunks what does this mean? Also, if the tractor runs with the injector return line disconnected, what does that mean?
