Compression pressure for G ?
JD720
10-27-2003 04:38:55
I just got a styled G to restore.I checked the compression pressure and it has 70 Psi.in both cylinders.Does anyone know what they are supposed to have? Thank you
JC
10-27-2003 19:27:20
 Re: Compression pressure for G ? in reply to JD720, 10-27-2003 04:38:55
I&T manual number JD-4 says 65 PSI at cranking speed for a Model "G" with serial number 13,000 and up.
Regards,
JC
tom
10-27-2003 12:43:43
JD,
The fact that they are both the same compression is good...meaning both cylinders/components are of equal quality, wear& tear.
If you want to test them a little further, try the same compression testing methodology you used before, but put a tablesppon or so of clean motor oil in the spark plug hole and let it set for a minute or two, then try again...if your compression goes up 15+ psi, then you have a good amount of wear on the piston rings, maybe the valves, etc...
good luck,
tom
Jack
10-27-2003 12:14:47
Thats not bad compression for a G with the original all fuel pistons.Get some high compression pistons and shave the head and it should be above 100 psi.55 hp with this set up is no problem to achieve.
