Removing Axles on Late B
Big Country
12-28-2005 13:30:26
I have a late B,I have some in play in my axles. So I guess the rear axles bearing are bad. What is the eastes way to get the axles out? Any help would be helpful.
Big Country
12-28-2005 14:32:25
 Re: Removing Axles on Late B in reply to Big Country, 12-28-2005 13:30:26
F-I-T, Thank's for the help. I think I have too much inplay in my axles, because they move side to side and up & down. I will try to tighten nuts up to if that works, but that sound to easy.
F-I-T
12-28-2005 13:38:12
Big:
The easiest way is to remove the rear cover (Powr-Trol box can stay put), then remove the rear wheel from that side, then place a wedge between the bullgear nuts, loosen the side you want to remove and as the nut turns off, it will push the axle outward out of the bull gear.
Now if the bearings are all right, you might just have to tighten them a notch or two or three.
Frank
