4455 Load control seals
Marquets
12-28-2005 11:59:48
I have a 4455 with a leaking load control seal. i have started taking this apart to establish the problem, but I'm not sure what I should find. My dealer has supplied me with two flat seals, whereabouts should I go about installing these. I have removed the end cap and the first bushing and pushed the shaft out a few inches the other side, I now come across a larger washer between the block holding the lift arms and the main block, after this there is a bushing and presumably somewhere my leaking seals.... could someone enlighten me
G/MAN
12-28-2005 13:38:39
 Re: 4455 Load control seals in reply to Marquets, 12-28-2005 11:59:48
A service manual would be of benefit. Go back to the dealership and have them copy the pages of the manual you need. That large washer is a shim to take up side play between the drawbar frame and differential housing. They are used "as required". Simply replacing the seals isn't a good long-term fix, especially if the bushings and shaft are worn. Wear on those parts will cause the new seals to start leaking in no time. It's best to replace the shaft, bushings and seals all at once.
Mike M
12-28-2005 12:09:02
I have not worked on one that NEW. But if it is set up anything like the older ones (4020)you are going to have to pull the shaft all the way out and then drop down the drawbar/3pt. frame so you can get to where you can reach the seals and bushings at the main tranny case.
