720 Flywheel Taper Lock Questions
Chatermb
12-28-2005 09:50:33
I bought a 720 diesel that my father bought new. The serial number is 7203929. I knew the flywheel was loose on the crankshaft when I bought the tractor. I read through the past posts on loose 720 flywheels but still have some questions.
Is there a dealer for Allen Machine Works taper locks in western Canada or in the northern plain states of the US? Or do I have to contact Allen Machine Works directly? Can I just buy the taper lock and get a local machine shop to do the machining? There is no point shipping to Tennessee a flywheel if the work can be done here.
chatermb
12-29-2005 06:26:23
 Thanks in reply to Chatermb, 12-28-2005 09:50:33
Thanks for your help on this question. I did not realize that you could buy a reproduction flywheel with a taper lock. That is an option to check out as it would avoid potential problems with a local machine shop machining the current flywheel.
I'll phone Allen Machine Works in the new year and get some prices.
Mike M
12-28-2005 11:09:42
 Re: 720 Flywheel Taper Lock Questions in reply to Chatermb, 12-28-2005 09:50:33
I see the problem. Those are awfully heavy and you live very far away. Years ago I was able to just buy the center part for a taper lock and machine it to fit myself. This was on a JD 60. Call them and see if they will still sell parts and instructions. You are however better off if you just buy a NEW reproduced flywheel made just for the taper lock system,these are much stronger in the center.I'd call Allen Machine and see what your options are they may even know if someone up your way stocks them.
8e3k0
12-28-2005 11:03:12
You can purchase complete flywheel with Taper Loc or Taper Loc sleeve assembly and machine your flywheel to accept the sleeve. For the NorthWest area give Albert a call at Renaissance Tractor in Chehalis, Washington at 1 800 784 0026 or 1 360 748 0026.
Ellis
