Interesting 4020
R. John Johnson
12-28-2005 07:36:53
Went to the In laws in Sioux Falls for Christmas. Went looking at tractors on dealers lots on the 26th. There was a 4020 on Pfieffer's lot that caught my eye. It had a Hinker cab I wish I had on my 4010. The front axle had been swapped out for a heavy Case 70 series axle. First time I saw one up close. Built like a brick outhouse. Looks like the way to go if you are having front end problems with a loader. The rear tires were 18.4 X 38's, but it had the cast centers for 34" rims. The clamps were 2" taller than normal to adapt the larger rim to the original center. Never heard of that before.
John
Magiver
01-02-2006 20:56:18
 Re: Interesting 4020 in reply to R. John Johnson, 12-28-2005 07:36:53
There is also a place south of Sioux City that makes the adapter plates. Can"t think of it right now.
JD man in SD
12-29-2005 20:59:49
John i have seen this done before i think Rockvalley Tractor wa 1st to make adapter plate also there are plates to adapt 5020 4430 4630 wide fronts to 3010 thur 4320 tractors the step up kits four 38 " wheels were made by M&W Gear CO
Kent
R. John Johnson
12-30-2005 06:52:32
 Re: Interesting 4020 in reply to JD man in SD, 12-29-2005 20:59:49
Kent
Thanks for the reply. Kinda felt good to be back in SD for a few days. I lived in Madison for 6 years.
I had heard of using other front ends, just this was the first Case I had actually seen and it impressed me. I was wondering who built the step up kit for 38" tires. Any idea if they worked well? are they common?
John
JD man in SD
12-30-2005 18:50:11
 Re: Interesting 4020 in reply to R. John Johnson, 12-30-2005 06:52:32
John the step ups worked good but not to common as wheeel rims came out later that did the some thing with stock clamps you may know me I owned & operated Kents Tractor Service from 1965 to 2000 still live in Madison area farm 3&1/2 qts and play with 2 cys
